Home > Technical > tailgate glass switch |
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 |
My tailgate glass switch has stopped working took out the switch sprayed it with contact cleaner tested it with my meter and the switch is completing the circuit. So I'm at a loss now so what else could it be.
Thu Jan 04 2018 10:47am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
broken wire in the rubber boot at the top of the tailgate maybe ?
Thu Jan 04 2018 12:40pm |
Cheers Andy will have a look when it stops peeing down hang on this is Bacup rain is normal weather , just hope it's not the lock god know how I'd get it out with the door closed If it ain't broken down it soon will
Thu Jan 04 2018 1:46pm |
Stopped raining so went out and checked if there was power to the switch socket nothing, there are three rubber boots which I assume are for the wiring/screen washer so which one has the wires I want to check.
Fri Jan 05 2018 11:08am |
I doubt you will see 12v at the switch.
Fri Jan 05 2018 11:46am |
Ah so an iid tool might help. I've ordered one from Dan he's running a group buy on the D3 forum so I'll wait for that. Cheers If it ain't broken down it soon will
Fri Jan 05 2018 11:51am |
Not sure if it can do it.
Fri Jan 05 2018 12:00pm |
Had a look
Fri Jan 05 2018 2:26pm |
I'll live with it for now, got another problem now the top fixing that holds the tailgate damper has sheared have a set of esi-outs so will tackle it tomorrow. I love landrovers I never get bored thanks for looking anyway Andy If it ain't broken down it soon will
Fri Jan 05 2018 3:09pm |
Well found out why the pivot bolt has sheared the damper had seized good job it didn't rip a hole in the body work. ordered a new pair to be safe plus they are handed If it ain't broken down it soon will
Sun Jan 07 2018 9:26pm |
