Home > Duckworth Parts > Under bonnet soft rubber buffers
Lindab
Hi Dan,
Could you please give me a price & delivery for the soft neoprene rubber buffer that sits on the wings near the bonnet pivot (picture enclosed). I need one for each side
2014 Range Rover Sport
Also what is the payment method
Regards
Charles
Post #544755 Thu Jan 04 2018 10:00am
PEACHY
Lindab - nice to see my pic came in use Thumbs Up
Part numbers should be L/H LR084527 and R/H LR084528
You might be better giving Dan a bell 01673849873 let us know how you get on with price & ask for forum discount Whistle
PEACHY 16MY Estoril Blue SVR.............
Post #544758 Thu Jan 04 2018 10:16am
Lindab
Peachy, Thanks for the use of your pic. It all came about by chance. I was asking about fitting a Ctek connector under the bonnet, protruding out the grille & got a reply from Col as he had done it protruding out the back of the bonnet. I had a look at his gallery pictures to see if he had one, it was there I saw a parts diagram of the buffer (which I have been looking for for a few days with no success). When I clicked on to it I saw it had come from you, so searched your name & posts & found the picture (I should have been a detective Rolling with laughter )
Do you know how they attach, are they glued or located in a hole. Have not removed mine yet until I get the new ones
Thanks again
Chic
Post #544761 Thu Jan 04 2018 10:35am
PEACHY
No problem Wink - it appears they are partly glued & located into a hole in the fender ( the part comes with a piece that protrudes ) the part may have a small glued piece that is covered by tape & removed for fitting purposes - if that makes sense.
I have emailed Dan directly for cost & availability - I will keep you in the loop Thumbs Up
Regarding your C TEK - Col has the L320 - You have the L494 the charging system setup will be different Wink I have the CTEK & used the quick crocodile clips for a charge under the bonnet - I was going to fit the fast c-tek connector but ran out of time - it will fit & the bonnet will close whilst the charger is in place Thumbs Up 16MY Estoril Blue SVR.............
Post #544762 Thu Jan 04 2018 10:41am
Lindab
Peachy, Ref Ctek, I also use the croc clips, but as the car isn't used much (6000 miles in 3 years) I was wanting to use the traffic light connector & have it sitting unobtrusively in the grille, then I will just plug in ctek when required without having to lift the bonnet. The ctek will be shared between the Sport & my F type Jag convertible which is used even less & is in hibernation till a sunny day in the spring Laughing . At least in the Jag it plugs onto a fag lighter socket in the boot (which has a permanent feed) with the long cable coming out of the boot lid & under the cover
Post #544771 Thu Jan 04 2018 12:10pm
PEACHY
Parts are £10 each - free delivery from Dan - plenty of stock Smile
Post #544784 Thu Jan 04 2018 2:12pm
Lindab
Peachy,
Phoned Dan, parts ordered, delivery in a few days. Thanks for all your help
Regards
Chic
Post #544788 Thu Jan 04 2018 2:56pm
Lindab
Parts arrived this morning. Thanks Dan for the fast despatch. Looks like an easy fit, one locating pin & some double sided tape.
Post #544955 Sat Jan 06 2018 1:54pm
Lindab
2015MY Range Rover Sport
Finally got round to fitting these, but the ones I received were much bigger than the ones on the car. Emailed Dan @Duckworths thinking I had ordered the wrong ones but he said the part were correct & they are the only ones available. Sad
Has anyone had this problem? Don't want to start cutting the new ones as they are neoprene open cell rubber & if you cut into the outer skin, they will absorb water like a sponge. Picture enclosed showing both parts. Existing one is approx. 170mm lg & new one is about 240mm lg
Post #556161 Thu May 10 2018 6:07pm
Prior to Vin. EA324041 they were a different part numbers, but they has been superseded to the same numbers as the current one's, there may have been a difference with in the earlier part though. Does the extra length not just fit up under the piece of plastic windscreen scuttle out of the way or are you referring to the piece which goes towards the outer edge of the wing ?.
Post #556187 Fri May 11 2018 3:40am
PEACHY
Lindab - I had the same as you - I made mine fit - I will post pics later today - by the way there is something about these deteriorating in Topix & may be replaced as a warranty issue Smile Watch this space. 16MY Estoril Blue SVR.............
Post #556190 Fri May 11 2018 7:02am
Lindab
Crisis over Shocked Plastic end covers have to be removed then they fit in. My fault, when I first looked at them they did not appear to have a bit that fits under the plastic covers Embarassed
Post #556424 Mon May 14 2018 2:37pm
Red Arrow
Looking for a pair of these under bonnet buffers myself and also offside rear rubber that sits in above the quarter pillar moulding Thumbs Up
Post #603602 Sat Aug 22 2020 11:24am
Red Arrow
Anyone help please Thumbs Up
Post #604223 Sun Sep 06 2020 7:19pm
Red Arrow
Anyone answering Duckworths messages ?
Post #605433 Fri Oct 09 2020 2:43pm
