Home > Technical > check auto fliud in gearbox.rrs v8 diesel auto.2007
raysheppard1954
hi .can the auto gearbox fluid level be checked or topped up on RRS ,Ive looked for a dip stick but haven't found one ,sorry if its a daft question .ray.
Post #544559 Tue Jan 02 2018 6:52am
There is no dip stick.
Obviously a mechanic can do it (via the level plug) with the engine running.
Post #544576 Tue Jan 02 2018 12:02pm
Vw1200
Bosnia Herzegovina 2010 Range Rover Sport 3.0 TDV6 HSE Bourneville
bottom of transmission.
2 bolts (drain and fill)
unscrew bolt for filling and it should start to leak in small volume (working engine), in case it does not, add ATF until it starts to drain.
I believe temperature should be at some level (not cold not too hot).
Post #544608 Tue Jan 02 2018 5:59pm
Bodsy
Site Sponsor
If you undo the filler without the engine running, then you will lose a lot of fluid.
Car needs to be level and gearbox oil temperature between 30 and 50 degrees.
With the engine running, Put the gear into reverse and then drive and manual 1,2,3
This fills the galleries as much as possible. Undo the filler and the oil should be filled until the oil dribbles out. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #544744 Thu Jan 04 2018 12:01am
and don't add red ATF.
use fluid for ZF6HP boxes
Post #544773 Thu Jan 04 2018 12:39pm
garrycol
Australia
Bodsy - question on this if I may - I want to do a sump change to the metal one and do a basic oil change at the same time (not a full/mega flush). I figured that if you ran the engine while dropping the fluid you would drop a lot more fluid as you have indicated above.
HOWEVER I was not going to do it as I was concerned that at some point the remaining fluid in the torque converter and gearbox would be too low with the engine running and would cause damage. Do you know if there is a time or some other criteria that allows the engine to run with the drain plug out before damage does occur?
I intended to do a second transmission oil drop in about 1000km after the first to maximize the amount of oil changed but getting the maximum oil out without damage would be helpful.
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #544852 Fri Jan 05 2018 1:04am
Bodsy
Site Sponsor
Whatever you do, do NOT run the engine whilst changing the filter/pan.
As soon as the pan is released, the gearbox oil pump will be sucking on air. Definitely not good for it!
It will take 4 changes of oil to get anywhere near to a full flush equivalent. But if you change the oil pan and then fill back up, just run the car and put into command shift 1,2,3. Then stop the engine, drop the oil again and refil.
Then do a single drop of oil at every service.
That’s probabky the best way to keep on top of it. Thumbs Up Bodsys Brake Bible
See it HERE
Post #544853 Fri Jan 05 2018 1:33am
garrycol
Australia
Thanks for your response = what I thought but I thought I would ask - thanks for the clarification Smile
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #544854 Fri Jan 05 2018 2:42am
The D3 boys have been doing this for years and it removes most of the oil.
Step 1 Disconnect oil cooler line at front and run engine for 20seconds or until oil stops coming out. (3.5 litres)
Step 2 Drain sump fluid. (2 litres)
Step 3 refit sump plug (or change filter)
Step 4 refill (which is slightly more difficult)
Step 5 level check.
Post #544866 Fri Jan 05 2018 11:55am
Bodsy
Site Sponsor
Not sure I’ve seen many doing that. Id never run the box until no oil comes out.
If you want to change oil easily, drain f rom the gearbox sump, refill with oil. (About 4-5 litres if you’re lucky)
Drive around the car park, drain again and refill.
That will change about 60-75% overall. Bodsys Brake Bible
See it HERE
Post #544916 Fri Jan 05 2018 7:26pm
Obviously its not great, but once in the life of the gearbox should be fine.
The great thing about the above method, is that when the oil goes back it it almost stays perfectly clean.
https://www.disco3.co.uk/forum/filos-autob...55010.html
Thread back to 2010
On page 10 garrycol seam to like the idea Laughing but put off as there was no bible.
Post #544922 Fri Jan 05 2018 8:42pm
