Home > Technical > Headlight removal
Morgi27
Headlight removal
Hi guys
Has anyone any more tips has how to get a stuck fast lever lock up to release the headlight
I've soaked in wd 40 even bent up the lip and pulled on it with locking mole grips it will not shift
I need to get light out to replace the bumper
Post #544441 Sun Dec 31 2017 12:37pm
Have you tried tapping it down first? That might break the muck that's holding it tight. I use a loop of thick string / thin rope to pull up the catches. You can get a decent pull up that way if needed. 2012 SDV6 - it's missing a couple of cylinders
Post #544446 Sun Dec 31 2017 1:30pm
Morgi27
Yes I've tried everyway
Post #544642 Wed Jan 03 2018 9:02am
