![]() | Home > Technical > Headlight removal |
Have you tried tapping it down first? That might break the muck that's holding it tight. I use a loop of thick string / thin rope to pull up the catches. You can get a decent pull up that way if needed. 2012 SDV6 - it's missing a couple of cylinders
Morgi27 Member Since: 31 Jan 2015 Location: Birmingham Posts: 88 ![]() ![]() ![]() |
Yes I've tried everyway |
