Home > Maintenance & Modifications > TDV8 Suspension arms
richtdv8
United Kingdom 2008 Range Rover Sport TDV8 S Java Black
Got worn suspension bushes (front) on my 2008 TDV8, it seems from what I have read that the way to do it is replace the suspension arms.
Can anyone recommend OEM arms or should I stick with genuine.
Has anyone out there have experience with non genuine units.
I am assuming this job can be done on axle stands, I have also read that the bolts will prob need cutting out.
thanks in advance.
Post #544276 Thu Dec 28 2017 9:29pm
Camelrock
When I did mine I changed the bushes as the arms where fine and the ball joints ok. Also make sure you mark the bolts before undoing/removing so you can put everything back in the same place. With using your old arms you don't need the 4 wheel alinement after because your fitting everything back as it was. A quick way to tell is if the steering wheel is as it was.
Done a few D3's like this have always kept a check on the tyre wear and pulling over never had a problem. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #544300 Fri Dec 29 2017 10:09am
richtdv8
hi, would certainly be cheaper to keep the original arms was just worried about changing the bushes.
are special tools required to change the bushes?.
Post #544302 Fri Dec 29 2017 10:42am
Disco_Mikey
If you have the facilities, changing the bushes yourself is cheaper
If you are paying labour to replace them, it's likely cheaper to replace the complete arms Thumbs Up
Post #544308 Fri Dec 29 2017 12:45pm
richtdv8
thanks, can the new bushes be fitted with just threaded bar and a socket
Post #544324 Fri Dec 29 2017 3:18pm
Tel02sport
What are people's. Thoughts on polly bushes ?
Post #545533 Thu Jan 11 2018 3:17pm
Camelrock
Sure iv read on the D3 site about sus monts cracking and breaking away from the chassis after fitting prolly bushes as to harsh and all the shock going into the chassis. Personally I would fit and indeed have fitted gen bushes on mine and a few D3s 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #545626 Fri Jan 12 2018 10:17am
d-9
Interesting, mine has fairly crashy ride and the front wishbones have been polybushed. How much are genuine bushes?
Post #545629 Fri Jan 12 2018 10:36am
Disco_Mikey
Polys are not nice. Had the local motor factor in trying to sell me some this morning
Until I pulled out the boxes of Superpro bushes Laughing
Post #545650 Fri Jan 12 2018 1:01pm
Bushes aren't that bad, to be honest.:
https://www.advancedfactors.co.uk/front-lo...-141-c.asp 2012 SDV6 - it's missing a couple of cylinders
Post #545668 Fri Jan 12 2018 5:27pm
d-9
Cheers! I think I'll swap those over at some point, see if it helps.
Post #545705 Fri Jan 12 2018 11:01pm
