Home > Technical > Best CTEK Charger to buy for RRS
warkman
England 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Had the dreaded flat battery today, so I am looking to invest in a CTEK charger
Looking at the MXS 5.0
Is this the right one for the RRS (2007, Deisel 2.7) Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #543582 Sun Dec 17 2017 2:56pm
warkman
Now faound a MXS7 cheaper..
Just one other question, what size are the eylets needed to fit to the battery?
8mm or 10MM?
Thanks all Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #543589 Sun Dec 17 2017 3:51pm
riverblanche
Which charger depends how you are going to use it Question
If you leave the car a few days between short trip use Then the lower spec can be fine as it has time on its side to get the battery fully charged, if it's short trips every other day then a higher spec one may be better suited, if you plan to do any work on the car (IID updates) then you may be best getting a 25
Don't know about terminal size, I either use the Tow electric plug or crocs to the jump lead posts, not direct to battery
(see Tim's post regarding solar charge)
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #543591 Sun Dec 17 2017 4:22pm
Buckster
I find tow bar electrics is the easiest way to connect and charge Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #543592 Sun Dec 17 2017 4:28pm
warkman
Unfortunately, my tow bar electrics are only 5 pin, not the 7 pin on younger models Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #543593 Sun Dec 17 2017 4:32pm
Tyrefitter
5 pin.? Never seen those,they are either 7 pin or 13 pin.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #543595 Sun Dec 17 2017 4:43pm
warkman
Sorry, you are right, 7 pin πŸ˜„ Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #543596 Sun Dec 17 2017 4:58pm
Buckster
Can use some 7pin as long as its not the one with black flap on it. Have a look in the forum shop as there is more info regarding 7 pin charging Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #543598 Sun Dec 17 2017 5:28pm
Cymruambyth
Wales
Sorry to hijack, I assume towbar electrics were an option? Steve.
Post #543599 Sun Dec 17 2017 5:32pm
yeap towbar electrics were option.
M8 size I think.
5 amp is fine. About Β£65 on the bay ?
Try and get a Free indicator lead M8. Good for connecting in the boot
Some of the ebay ones have this bundled in
Post #543605 Sun Dec 17 2017 6:11pm
http://www.ebay.co.uk/itm/CTEK-Multi-MXS-5...Sww9xZAi8i
Post #543606 Sun Dec 17 2017 6:26pm
MXS7 or MXS10 they have the advantage of having a separate 12 volt power supply should you need it to retain memory on a vehicle etc.
This is how I connect mine, just tucks back under bonnet out of the way, never had any problems with water ingress during rain etc. saves having to remove tow bar cover etc. as well.
Post #543623 Sun Dec 17 2017 9:29pm
warkman
Just ordered the MXS7 with extension lead and battery connectors.
Unfortunately, the tow plug socket is the black sap 7 pin Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #543634 Sun Dec 17 2017 11:08pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I have 3 C-Tek MXS-5 units and I find the mode switch becomes unresponsive after a while from new. They work but the mode switch does not seem to change the setting until it has been pressed a few times. The issue is the same for all 3 units I have. When they are new they responded instantly. I would go for the MXS-7 as I find the MXS-5 a bit undersized for the RRS battery.
Post #543643 Mon Dec 18 2017 5:27am
warkman
Where does your comfort connection come out? Can’t quite fathom it πŸ˜€ Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #543730 Tue Dec 19 2017 7:14pm
