Home > Technical > Transmission fault message.... Now gone..
Jampot1979
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Had the transmission fault message come on after initial start up today... Turned off and on again, car did systems check and no errors....
Driven the car all day without no issues... Gear changes fine etc...
Do you guys think it could be the battery having low voltage, cold weather?
Seems fine, all programmes are working etc.
Cheers Thumbs Up
Post #543597 Sun Dec 17 2017 5:18pm
Tyrefitter
Mine did this yesterday,started up & drove to fuel station with no problems,,when I started up to pull off pumps it’s wouldn’t go into any gear,,turned engine off & back on after 3 time it eventually went into gear & not been a problem since,,I’m going to plug diagnostics in tomorrow & see if it comes up with any codes or errors.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #543602 Sun Dec 17 2017 5:34pm
Eaters
This may be of help, or not...
http://www.rrsport.co.uk/forum/topic49419.html Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #543611 Sun Dec 17 2017 7:05pm
GodivaNige
Recently I was getting transmission fault messages on startup. On checking with the IID tool, a couple of faults recorded ‘clutch actuator stuck’ and ‘clutch adaptive learning at limit’
After some searching, a few forums pointed towards possible bad electrical connections at the transfer box. I put the car on ramps and removed each of the three plugs, cleaned up the contacts and refitted. Also found a loose earth strap from the transfer box to the body, so tightened that too. No transmission faults for the last couple of weeks so looks like It’s sorted.
Your fault might be down to low battery power, or brake light bulbs, or any one of the other little foibles that can give unrelated alarms with these cars, but to be sure, getting the codes read with a proprietary reader will help you out.
Post #543616 Sun Dec 17 2017 8:17pm
