Home > Faults & Fixes > steering wheel vibrating but tracking and alignment done |
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 |
Could be tyre pressures- I have had that fault. Also could be your tyres don’t match, ie tread patterns Noisy black one |
Wed Dec 06 2017 11:12am |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
Balancing? I have this with my 22`s but haven`t had it looked at yet. Steve. |
Wed Dec 06 2017 11:29am |
sounds like you have a wheel or 2 out of balance.
Wed Dec 06 2017 11:32am |
wings21660 Member Since: 11 Feb 2015 Location: Gretna Posts: 65 |
I had this on MY11 Autobiography turned out to be warped hubs |
Wed Dec 06 2017 12:45pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 |
Had this on my 22's, took the email to everyone balanced but found that the 2 fronts were slightly oval. Managed to get them squeezed back into shape and all's been fine since 2010 RRS, TDV8
Wed Dec 06 2017 2:38pm |
Don't even ask what I was talking about in the previous post 2010 RRS, TDV8
Wed Dec 06 2017 2:39pm |
craigdunne Member Since: 01 Dec 2017 Location: MIDDLESBOROUGH Posts: 11 |
Thanks guys for your reply. I had the tracking done but still the same. he did mention the wheels didn't sit right on the hub so maybe that's the problem. i will explore more. |
Thu Jan 04 2018 3:02pm |
Do you know exactly what he meant by this? Could be the wheels need spigot rings fitted. Have a look at this: https://www.spigotrings.com/index.php?route=common/home OR, I'm sure in the past a couple of owners have had apparently inexplicable vibration and it turned out to be water inside the tyres. Poorly maintained compressors can put water in your tyres when you top them up. 2008 MY Java Black TDV8 HSE |
Thu Jan 04 2018 3:20pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Get the wheel balancing checked like Andy says, quick and easy to eliminate. 2006 2.7 TDV6 HSE in Cairns Blue. |
Thu Jan 04 2018 4:05pm |
Ferret15 Member Since: 11 Jun 2017 Location: Somerset Posts: 31 |
I had this on my 22 which came on the rrs 08 when I brought it. Two ended up having small cracks in them. I’ve since gone down to the 20s and the difference in ride comfort and noise is incredible. |
Sun Jan 07 2018 10:29am |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 311 |
I had this issue on my tdv8, it was warped brake discs. Does it vibrate worse under braking?
Sun Jan 07 2018 10:52am |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 160 |
have you ever used tyre weld,,this can put them out of balance |
Sun Jan 07 2018 10:57am |
I was amazed at the difference from 22 down to 20s. But if you says it’s bad enough on 20s then I think I maybe tempted to change again. When is the best size to be on? |
Sun Jan 07 2018 11:54am |
You cant go much less than 20's as i assume you have brembo front breaks so i think some 19's fit but you need to check or you can use a 45 series tyre which will improve the ride a bit |
Sun Jan 07 2018 1:13pm |
