![]() | Home > Technical > christmas tree lights |
Ade99 Member Since: 28 May 2014 Location: wombourne Posts: 20 ![]() ![]() ![]() |
Hi all
You do need to get the codes done but does sound like maybe the alternator is maybe om its way out |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I would support the thought that it is more than just the alternator. I drove mine for 16 miles on a brand new fully charged battery but with no alternator charge (not intentionally) and it only stopped when the battery went flat.
Thanks for the replys is the brake switch under the brake pedal or located somewhere else? |
Here, this may help (I've not changed one myself):
Ste815l Member Since: 22 Sep 2017 Location: Newcastle Posts: 30 ![]() ![]() ![]() |
Yes it's located behind brake pedal only a £10 part. Try using some wd40 or electrical spray on the switch as they can get gummy and stick. But signs of this will be brake lights constantly on. |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
For what they cost and the time the part takes to change, it’s worth going ahead and replacing it. It is also worthwhile carrying a spare in your glovebox.
Hamtheman Member Since: 18 Jan 2017 Location: Joburg Posts: 33 ![]() ![]() ![]() |
I had a similar issue , the cause was found to be loose battery terminals due to some serious gravel roads, nipped them up and all good. |
Thanks for the advice going to check the battery tonight and put it on charge and have a look at the brake switch and lights and try to start it tomorrow after the battery has had a good charge |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Check for loose earth connection points too. There are a few dotted about with about 5 in the engine bay. A loose one can cause issues. 2012 SDV6 - it's missing a couple of cylinders
Thanks for all the great response looks like I have a lot to check.
Had a busy day today and just the sort of weather to be outside messing with the car.
Well done Ade. Hope the good news continues.
