![]() | Home > In Car Electronics > Head unit and nav |
Try mmj on here they are breakers who sponsor this site go for second hand from them if they have one or another breaker unless you have a wad of cash burning a hole in your pocket |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 ![]() ![]() ![]() |
Normal |
You should be able just to buy one and change it over but to be sure if its not working take it out and check the number to be sure but i am pretty sure they are all the same as long as its just Harmon Kardon |
I’ve noticed a couple different model numbers on eBay so I’ll remove to check mine
There not hard to get out but make sure the people on ebay accept returns mmj are on there as well |
Amp arrived today fitted but not working fault code now is
I spoke to rangerover dealer today they told me amplifiers are coded to the car so second hand amp won’t work in my car
Second amp arrived today same problem fibre optic failure
It may be the tmc part itself unless the fuse is blown then there should be power there unless you are unlucky enough to have a break in the wire |
Just tested power lead all ok so unit needs replacing
I managed to buy a used TMC from eBay for £21 delivered now all sorted
And how much and what sis the stealers say |
