![]() | Home > Technical > Car heating not working |
Deuchars Member Since: 26 Jul 2015 Location: North Wales Posts: 38 ![]() ![]() ![]() |
My 08 RRS's Heating suddenly stopped working. The blower and all the controls work OK, just no heat coming out of them. If I put the air con on to cool then things get very cold as they should, but if it's turned up to max still no heat. I've had it into my local indie to check out the usual problems, and apart from a small leaky pipe, everything is good, No air lock or blockage in the heater matrix, all pipes are nice and hot etc
Check the relay or most likely the module that sits in the air pipe behind the passenger glove box. Held in by two screws. Bodsys Brake Bible
Hi, thanks for your reply. I've just been having a look, seems like there's a lot of relays and fuses behind the glove box. Is this the part you were talking about? How do I access it and check if it's working? Thanks
Full led light pack, HST front grill, black lettering.... Great to be back on Petrol..... Mini Cooper SD......New arrival Nissan Navarra....gone Mercedes C320 cdi...gone Mini Cooper D.... Subaru Impreza Sti....gone Land Rover Discovery....gone Many more over the years...all gone... |
I've read on this forum about a test to do on the heating by holding down the econ and recirculate buttons, then switching on the ignition. I did this and the econ button flashed Ten times. What I need to know is what does it mean! Is that what it does when everything is OK, or when it's not OK?
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Is your engine reaching temperature ?
The drivers side heating is getting hot now, but only on low fan settings. If I turn the blower up high it goes cool again. The passenger side blows cold all the time. When I tried the air con self test, the defrost light never flashed at all after turning the ignition back on.!
Leath31 Member Since: 21 Aug 2017 Location: Midlands Posts: 9 ![]() ![]() ![]() |
Hi , iv got the same issue that you had, so did you sort yours out just by holding down the 2 buttons while starting the engine ? |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
There’s possibly either a problem with one of the temperature sensors linked to the climate control which is indicating the cabin temp is warmer than it actually is, or there’s an issue with the air mix temperature control flap motors. The only way to determine what is causing your problem is to check for any faults stored with something like an IID tool and to also check live values for the climate control are what you would expect them to be. i.e. if the cabin is cold, is the climate control ecu seeing the same or has a temperature sensor gone out of calibration? |
holding 2 buttons down just allows you to see the fault codes |
Spitty Member Since: 28 Jun 2022 Location: Gloucester Posts: 3 ![]() ![]() ![]() |
Sometimes the search and old threads resolve the problem. Back to having hot ir at my feet again!! |
