Home > Technical > Car heating not working |
Deuchars Member Since: 26 Jul 2015 Location: North Wales Posts: 38 |
My 08 RRS's Heating suddenly stopped working. The blower and all the controls work OK, just no heat coming out of them. If I put the air con on to cool then things get very cold as they should, but if it's turned up to max still no heat. I've had it into my local indie to check out the usual problems, and apart from a small leaky pipe, everything is good, No air lock or blockage in the heater matrix, all pipes are nice and hot etc
Tue Jan 19 2016 8:44pm |
Check the relay or most likely the module that sits in the air pipe behind the passenger glove box. Held in by two screws. Bodsys Brake Bible
Tue Jan 19 2016 11:31pm |
Hi, thanks for your reply. I've just been having a look, seems like there's a lot of relays and fuses behind the glove box. Is this the part you were talking about? How do I access it and check if it's working? Thanks
Wed Jan 20 2016 9:13am |
I've read on this forum about a test to do on the heating by holding down the econ and recirculate buttons, then switching on the ignition. I did this and the econ button flashed Ten times. What I need to know is what does it mean! Is that what it does when everything is OK, or when it's not OK?
Sun Jan 24 2016 6:44pm |
Is your engine reaching temperature ?
Thu Feb 04 2016 4:25pm |
The drivers side heating is getting hot now, but only on low fan settings. If I turn the blower up high it goes cool again. The passenger side blows cold all the time. When I tried the air con self test, the defrost light never flashed at all after turning the ignition back on.!
Thu Feb 04 2016 6:48pm |
Leath31 Member Since: 21 Aug 2017 Location: Midlands Posts: 9 |
Hi , iv got the same issue that you had, so did you sort yours out just by holding down the 2 buttons while starting the engine ? |
Sun Nov 12 2017 8:58am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
There’s possibly either a problem with one of the temperature sensors linked to the climate control which is indicating the cabin temp is warmer than it actually is, or there’s an issue with the air mix temperature control flap motors. The only way to determine what is causing your problem is to check for any faults stored with something like an IID tool and to also check live values for the climate control are what you would expect them to be. i.e. if the cabin is cold, is the climate control ecu seeing the same or has a temperature sensor gone out of calibration? |
Sun Nov 12 2017 9:15am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
holding 2 buttons down just allows you to see the fault codes |
Sun Nov 12 2017 10:25am |
Spitty Member Since: 28 Jun 2022 Location: Gloucester Posts: 3 |
Sometimes the search and old threads resolve the problem. Back to having hot ir at my feet again!! |
Sat Dec 23 2023 5:21pm |
