![]() | Home > General > Detachable Tow and LR |
I thought if they inspected it and it was not fit for purpose ie to much movement then they replaced it free of charge |
Michael997 Member Since: 31 Jan 2006 Location: Worcestershire Posts: 228 ![]() ![]() |
So did I, but only if they deem it unsafe and mine is loose but passed whatever their test is Michael
Shouldn’t be covered by warranty unfortunately, reading the warranty T&C, it’s exempt, comes under normal wear and tear, and even if brand new and fitted by LR, has a max 2 year warranty now from new.
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 ![]() ![]() ![]() |
Hi , my 2008 tdv8 went into local main LR dealer on Thursday for new front bushes and when I got there they told me they were going to inspect my detachable tow bar as part of a recall under warranty!! as well as the work it was in there for ! Though when I picked it up they made no mention of the result of their inspection ! I can only assume they found it to be ok ! 🤔 |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
My car didn't have the tow pack on it when new but I'm just looking in to having it fitted as it looks like I will need to tow a car trailer with my cossie on the back to get it mapped.
First time I went to fit mine it was so tight I couldn't even get it in, yet alone it being loose and fall out, had to actually ease it slightly with a file, so imagine it becomes loose over time and use.
Thanks for the info will check tomorrow! |
Thanks for all the comments, I decided the risk was too great to continue with the detachable bar so I bought a Witter fixed bar for £132.00 and fitted it today myself, peace of mind at last when towing.
Rocha_99 Member Since: 26 Feb 2018 Location: Preston Posts: 1 ![]() ![]() ![]() |
Which Witter tow bar did you choose? |
Hi
