![]() | Home > Technical > Suspension issue. |
He might have been bleeding the system rather than changing the filter. If the filter needs changing so often then there's something more amiss.
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
No...all he did was tap the unit with a small hammer and use some electrical spray. He said they can get blocked and a light tap usually sorts it.
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Evening Cymruambyth,
Hi..no I don`t have a reader but there`s a garage up the road who has one. I`ll pop up on Monday |
Tapped with a hammer and sprayed? This isn't a Series III ! I doubt a tap with a hammer would clear a filter... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
It seemed to solve it.....till now |
Hi Cymruambyth, not sure if this would help you, seeing as you are in North Wales, and can’t be that far from me, Abergele/ Llandudno area, if you would find it useful you could pay to have your VIN number added to my GAP Diagnostic account, and then you can come across or meet, and be able to use my IID BT tool when required, to read errors, make alterations etc.
Ahhhhh thanks Johnski...really appreciate that |
No problem the offer is there just in case, once I’m driving fully again, I could always meet half way if required. |
Nice one, cheers matey |
I`ve been to the garage. He plugged is reader in and there were about 17 faults, old and new. He cleared them all, then I drove round the block and the amber DSC light came on.
so the only ones you need to worry about are the 2 dsc comms issues then which could be a loose wire a broken wire or a faulty modual |
Yeah exactly. He did say it wasn`t a broken wire though |
If its not a broken wire how does he know for definite |
