Home > Technical > Suspension issue. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
He might have been bleeding the system rather than changing the filter. If the filter needs changing so often then there's something more amiss.
Fri Nov 03 2017 3:43pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
No...all he did was tap the unit with a small hammer and use some electrical spray. He said they can get blocked and a light tap usually sorts it.
Fri Nov 03 2017 3:46pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
Evening Cymruambyth,
Fri Nov 03 2017 6:19pm |
Hi..no I don`t have a reader but there`s a garage up the road who has one. I`ll pop up on Monday Steve. |
Fri Nov 03 2017 6:22pm |
Tapped with a hammer and sprayed? This isn't a Series III ! I doubt a tap with a hammer would clear a filter... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Nov 03 2017 6:36pm |
It seemed to solve it.....till now Steve. |
Fri Nov 03 2017 6:37pm |
Hi Cymruambyth, not sure if this would help you, seeing as you are in North Wales, and can’t be that far from me, Abergele/ Llandudno area, if you would find it useful you could pay to have your VIN number added to my GAP Diagnostic account, and then you can come across or meet, and be able to use my IID BT tool when required, to read errors, make alterations etc.
Sun Nov 05 2017 2:06pm |
Ahhhhh thanks Johnski...really appreciate that I`m in Wrexham, so about 45 - 50 miles from you. I`ll see what I get charged tomorrow and then work out supercharged fuel costs Steve. |
Sun Nov 05 2017 6:33pm |
No problem the offer is there just in case, once I’m driving fully again, I could always meet half way if required. John
Mon Nov 06 2017 12:10am |
Nice one, cheers matey Steve. |
Mon Nov 06 2017 10:52am |
I`ve been to the garage. He plugged is reader in and there were about 17 faults, old and new. He cleared them all, then I drove round the block and the amber DSC light came on.
Mon Nov 06 2017 2:03pm |
so the only ones you need to worry about are the 2 dsc comms issues then which could be a loose wire a broken wire or a faulty modual |
Mon Nov 06 2017 2:46pm |
Yeah exactly. He did say it wasn`t a broken wire though Could just be the filter in the module hopefully. Steve. |
Mon Nov 06 2017 2:48pm |
If its not a broken wire how does he know for definite |
Mon Nov 06 2017 2:50pm |
