Home > General > What should be Underneath the windscreen scuttle panel |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
Before you start stripping down your vehicle have you checked that the sunroof drains are not blocked? This can sometimes result in a wet carpet in the passengers or drivers footwell.
Sat Nov 04 2017 2:35pm |
Steve,
Sat Nov 04 2017 3:59pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
Water cannot get into the cabin from under the scuttle - it does not seal against the body - you can drive around without it and will make no difference - the scuttle cover is just for show.
Sun Nov 05 2017 2:27am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Thanks everybody for your quick replies. When I had the windscreen checked the second fitter noted that the first fitted had not bunged up the holes, which he did so I know that's been done. I'm going with Paddi's - the ill fitting scuttle theory so this morning in the light I'm going to have a good look and get a decent seal first, plan b will be O level craft and get a bottle cut to make a shelf
Sun Nov 05 2017 7:09am |
Sorry Garry old chap but unless export spec vehicles are different you are wrong about the scuttle cover. There is even a TSB about it. The TSB covers several sources of water leaks including the pillar trim problem for which there is a repair kit available. Steve, Hope you get it sorted today. 2008 MY Java Black TDV8 HSE |
Sun Nov 05 2017 9:43am |
Well I can only relate my own experiences - the seal on my scuttle is greatly buckled due to our UV and as such has lifted a few cm above the lower windscreen in a number of places - water runs straight down the windscreen through the holes into the plenum area under the scuttle - no water gets into my car.
Sun Nov 05 2017 10:55am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5001 |
Technical Bulletin LTB00034 Passenger Compartment Water Ingress, consists of eight pages. Cheers Col |
Sun Nov 05 2017 11:01am |
Thanks Col, I've a copy of that TSB somewhere in my files and it sure doesn't mention anything about rust!
Sun Nov 05 2017 4:43pm |
Hi Paddi,
Sun Nov 05 2017 7:52pm |
Thanks for the info Paddi, sealed the lip above the VIN area that was lifted and after yesterdays rain the car is bone dry
Wed Nov 08 2017 12:45pm |
Wed Nov 08 2017 5:08pm |
