Home > In Car Electronics > Most loop |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Yes, the head unit is the master |
Sat Oct 28 2017 3:14pm |
So i have no red light does this mean i have a head unit problem |
Sat Oct 28 2017 3:17pm |
Have you been having other problems? Any DTC faults logged?
Sat Oct 28 2017 3:28pm |
No other issues just swapped the wires on my D4 screen yesterday as had poor radio reception then noticed i had no red light now nothing no radio no sat nav nothing but everything else is ok |
Sat Oct 28 2017 3:40pm |
Sun Oct 29 2017 1:33pm |
Would anyone know how to test the system when i dont have power to the head unit so cant turn it on to test the most ring |
Sun Oct 29 2017 2:32pm |
Does anyone know if there is a fuse inside the head unit as i have 12 volts going in but nothing works on the head unit or somewhere i can get it tested having read the pdf Godivanige |
Mon Oct 30 2017 8:36am |
I know my local indy has the equipment to test and repair problems with the MOST loop, but they're nowhere near you. Venture 4x4 in Warwickshire. They've sorted out a few RRS's and Discos in the past according to their FB page.
Mon Oct 30 2017 8:43am |
thanks have seen a few on the bay dont know weather to buy a cheapy to make sure it is that or to try and find someone who knows something about them and get it tested to confirm as i have power to the unit but nothing at all lights up or works and no light coming out of head unit |
Mon Oct 30 2017 8:51am |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
this is from the FFRR's wiki page and might [or not] help you,
Mon Oct 30 2017 10:25am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4943 |
If you have 12v at the connector, and press the volume button knob the display should come on.
Mon Oct 30 2017 12:09pm |
Thanks everyone just checked continuity of fuses and 43 was knackered so result cheap fix |
