![]() | Home > In Car Electronics > Most loop |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Yes, the head unit is the master |
So i have no red light does this mean i have a head unit problem |
Have you been having other problems? Any DTC faults logged?
No other issues just swapped the wires on my D4 screen yesterday as had poor radio reception then noticed i had no red light now nothing no radio no sat nav nothing but everything else is ok |
Would anyone know how to test the system when i dont have power to the head unit so cant turn it on to test the most ring |
Does anyone know if there is a fuse inside the head unit as i have 12 volts going in but nothing works on the head unit or somewhere i can get it tested having read the pdf Godivanige |
I know my local indy has the equipment to test and repair problems with the MOST loop, but they're nowhere near you. Venture 4x4 in Warwickshire. They've sorted out a few RRS's and Discos in the past according to their FB page.
thanks have seen a few on the bay dont know weather to buy a cheapy to make sure it is that or to try and find someone who knows something about them and get it tested to confirm as i have power to the unit but nothing at all lights up or works and no light coming out of head unit |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
this is from the FFRR's wiki page and might [or not] help you,
If you have 12v at the connector, and press the volume button knob the display should come on.
Thanks everyone just checked continuity of fuses and 43 was knackered so result cheap fix |
