Home > Technical > Cool box/fridge retro fit
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
Well as my car never came with the cool box I was wondering if its possible to retro fit one I've had a good search of the forum but can't really see much on this, so does anyone know if its possible, if so is it just plug and play or does a CCF need changing and if it does will the GAP IID tool be able to do this. My car is a MY2012.
Another question for those of you that have the cool box, is it actually worth having, do you use it or is just another place for putting CD's etc. Thanks.
Post #538392 Mon Oct 16 2017 7:25am
Buckster
I think it can be done, and the loom will already be there for it. In a Discovery 4 it was an option but it is easily retrofitted and plug and play so i dont see the sport being any different Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18ā€ Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning šŸ˜Ž
Post #538393 Mon Oct 16 2017 7:41am
geoffsnook
if everything is the same as a disco 3/4 then it is easy to retrofit i did mine with a fridge from a disco 4 all the wiring is in place and it was plug and play and it does cool drinks and chocolate well Thumbs Up
Post #538397 Mon Oct 16 2017 9:27am
david007
Thanks for the replies, Just had a look at prices and if this is the correct part No LR076833, the price seems quite reasonable, in fact a new one seems to be cheaper than some are charging for second hand units on Ebay
Post #538399 Mon Oct 16 2017 9:36am
david007
Well I contacted Dan and he confirmed the cool box is plug and play, part No is LR076833. So I've ordered one and will fit it when next home. Also got a slight discount on RRP.
Post #538577 Wed Oct 18 2017 9:17am
Johnski
I’m sure that Dan would have checked, but there is many different models and lid variations, depending on year and VIN number, I was surprised at the different models and facilities and finishes etc.
List of most here:
https://www.rimmerbros.co.uk/Item--i-GRID019532 John
Post #538585 Wed Oct 18 2017 11:59am
david007
I think there's only two models you need to pick from now, either LR076833 or LR075160 this seems to have superseded the previous earlier type of cooler, no need to purchase a lid it just needs transferring over.
Post #538594 Wed Oct 18 2017 1:28pm
Johnski
The box doesn't come with the tray as standard either. Whistle
Most say it is purely a cooler as doesn't get temperatures low enough to make it useful, I personally haven't had that problem yet, but it only just hits 10c after being on for a couple of hours run. Drinks etc are cool enough to enjoy IMO. Leaving the tray off virtually stops it getting cool enough though. John
Post #538597 Wed Oct 18 2017 1:44pm
It's just a Peltier cooler on an uninsulated box so its performance is always going to be a bit limited really. I guess one could insulate the box which would help things stay cool for a bit longer once the engine is switched off.
I find it's a boon on long drives where you can have nice cold drinks to hand. It'll fully cool four 500ml bottles in an hour, in my experience. 2012 SDV6 - it's missing a couple of cylinders
Post #538608 Wed Oct 18 2017 4:00pm
