![]() | Home > Maintenance & Modifications > Where do i buy exhaust mod? |
I’m just in the process of having my middle box & resonator removed & straight pipes put in their place,,I’m just cutting them then getting another straight pipe then sleeving it.Mine is the 5.0 but the exhausts are similar.
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 ![]() ![]() ![]() |
Hi pal I have just had one custom made from quick silver cost me £1000.00 it makes TDV8 sound like a V8 Petrol Awsom, I can not imagine what yours would sound like after having it installed, I am sure you will not be disappointed, please note I have nothing to do with quick silver I only used them as my Local Indi Recomended them!
Tome Member Since: 20 Mar 2016 Location: West midlands Posts: 21 ![]() ![]() |
Cheers for the replys, the more i look the harder it is to decide haha how much are you paying for the resonator delete?
This is like my exhaust system & we are going to cut behind the resonator box marked red & at the front of the box it slides over where it comes from the cats,,so we are just going to get some straight pipe & sleeve both pipes front & rear,,job done at a cost of about £80-£100.
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Have you looked at MIJ Performance Walsall? I’ve had a couple of stainless bespoke exhausts made by them and both were superb. One on a V6 Vectra VXR and they made a like for like exhaust for my Westfield. Both had first class welding. They offer a while you wait service and we’re very competitively priced. Think I paid around £400 for the Vectra for a complete hand made cat back system. |
I was just going to do that with my exhaust but the pipe needs bending on the 4.2 to line up by the looks (thats what it looks like on this pic i found on here anyway)
Have you about cutting it then sleeving it with a piece of flexi.something like this.
I have not thats a good idea, i will check see if there is enough left on the pipe to clamp too, could be an option |
I am going with that option Andy 👍 i figure if i like the sound i will investigate more and get one made. I have measured the exhaust it is just under 56mm... can only find 54mm or 57mm pipe, there is always an issue 😂 i guess go for 54mm and clamp it down. |
Here you go Tome,,mines 55mm at rear but I’m also removing front box which is 60mm so I’ve got a sleeve with 55mm at one end & 60mm at the other.
Thanks for all the info guys, took a while i know! But finally got round to doing it and s**t it sounds good!! Much better than i expected!!
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
So what did you do in the end? Remove the 1 centre box? I`m having second thoughts now about doing this. Steve. |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Any one done this on the 3.0 tdv6? Really tempted after hearing an SC pullout in front of me last week with a modded exhaust.. |
V8 is the only way to go.This is what mine sounds like with the middle box & resonator removed.
