Home > Maintenance & Modifications > Thinkware F770 Voltage Setting
Eaters
Hi guys. A bit of advice please from those of you with this Thinkware dashcam. What voltage have you set for it to shut down to prevent battery drain. I've got mine on 12 volts currently but that means it doesn't stay on long in park recording mode before turning off. Wonder how low I could set it but still leave enough power (with a margin) to start the car. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #537539 Fri Oct 06 2017 3:40pm
DrRob
I might get one of these and tuck it under the passengers seat. I currently power my dashcam with a long lead routed to rear seats 12V socket.....
http://www.techmoan.com/blog/2016/5/27/das...arked.html Visitor from fullfatrr.com
Post #537557 Fri Oct 06 2017 4:48pm
I used to run myself be on 11.8 and the next down 11.6? And never had a issue with starting
Post #537558 Fri Oct 06 2017 4:50pm
Oldandconfused
I just installed mine and its set at the highest to see how it gets on as I don't know what state the battery is in. I previously had it in my 2015 Honda Civic on the same setting and as far as I could tell, it never shut down. Of course, that was a 12 month old battery Very Happy .
I will be interested to see how you guys get on with it.
Post #537564 Fri Oct 06 2017 5:22pm
Eaters
That looks a really good option - but at a price.
I'll take a chance on the npinks route at least initially and try a lower voltage setting to see how that goes (flat battery, here I come... Confused ) Robin
Gone:
MGZTT 190 2.5
Post #537566 Fri Oct 06 2017 5:33pm
muddywheels
Milk Float Man
When I had the RRS I had a Blackvue and had to set it on lowest voltage or it would switch off in winter with heated seats etc on
When I got the DS with auto stop/start I found connecting ctek through tow socket when parked at home but not used helped keep battery topped up otherwise Thinkware switched off as soon as I parked
Had no issues with Mitsubishi PHEV as it's plugged in when parked and tops up start battery daily automatically
I've fitted Thinkware in Lexus now too but not checked to see how it's working - will look at this over weekend Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #537594 Fri Oct 06 2017 10:17pm
