![]() | Home > Maintenance & Modifications > SC exhaust |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Thanks Scumpy,,I'll get mine on the ramp & check what needs doing.
Hi Scrumpy,,is the the piece you cut out.?
Hi Andy,
The snail shell is effectively a big baffle box and I removed that and fitted 2 stainless still pipes in place, welded onto the back of the first collector box and onto the pipes that then separate off to the rear silencers each side which you can see in the next 2 pictures;
The “snail shell” can be refitted later if needed! Hope that helps! 2016 RRS SVR Estoril Blue 2005 4.2L Supercharged Java Black - gone but was my first love. -------------------------------------------------------------------------------------------------------- If we all point our RR's in the same direction and accelerate at the same time can we turn back time? |
Yes scrumpy,,im sure that's the bit that's been cut out,,this is the link to the full exhaust system on flea bay.
Looks like it to me too.
Ive also got the black letters for it of flea bay,,£39.95 with the L494 template,,Dan at Duckworths wanted £240.Plus Im ordering some sidesteps.
This one sounds awesome |
That is in Sloane Street in london, near Harrods where you get all the supercars with Arabic number-plates! I live and work close to there!
Does the standard SC exhaust change sound when in sport mode.?
It does change sound in Sport mode but only because of the higher rev range (Sport mode lets the revs increase between gear changes from about 2500 rpm to 7000 rpm).
Ive had a price from a company about £700 for exhaust but I need to also change rear bumper for svr type & we are then going into 000's which I don't want to do.
hodjie Member Since: 13 Nov 2013 Location: United Kingdom Posts: 91 ![]() ![]() ![]() |
hi ,I got mine direct from overfinch for a £1000 . pops and bangs more then my tvr cerb |
