Home > General > head gasket
Ratman
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
head gasket
hi guys
any one heard of the head gasket leaking on the rrs 07 2.7td
dealers told me head gasket never leaks on range rover sport ,only engine blow due to lack of servicing
due to oil
because my rrs is leaking
just wondering
Post #536273 Sat Sep 23 2017 7:49pm
Leaking what where
Post #536277 Sat Sep 23 2017 8:49pm
Ratman
water in bottle ,got to top up every day
been told head gasket anyone heard of this on RRS ??
Post #536435 Tue Sep 26 2017 6:09am
geoffsnook
Very few head gaskets go but there are other parts that leak there is a y shaped piece of plastic at top of engine that has been know do leak have a look on here Thumbs Up
Post #536437 Tue Sep 26 2017 7:04am
geoffsnook
https://www.disco3.co.uk/forum/topic153969...water+loss
Have a look here Thumbs Up
Post #536438 Tue Sep 26 2017 7:16am
Is there more/different exhaust smoke on idle ? e.g grey/white ? This would point to headgasket or EGR's failing
Post #536455 Tue Sep 26 2017 11:08am
Ratman
no white smoke, oil nice and new no cream, had head gasket check today the garage put a big tube on the water bottle
with red fluid in, starting engine and the colour went from red to orange
which says head gasket gone in the exhaust side, so I was told !!
now I been told need engine instead of new head gaskets because of the cost
what do you guys on here feel ??
Post #536525 Tue Sep 26 2017 10:09pm
Disco_Mikey
Or EGR coolers Wink
Post #536530 Wed Sep 27 2017 6:10am
You don't replace one of these engines that runs just because of a coolant leak.
When the EGR coolers fail, this doesn't pressurise the coolant though? or does it?
First need to dis connect coolant pipes from egrs and see if that fixes it
Post #536540 Wed Sep 27 2017 8:29am
Ratman
not long had new EGR both side
Post #536592 Wed Sep 27 2017 9:36pm
Ratman
Thanks Andy k
I will have to book in to garage for this ,pressure is coming from some where unless the new egrs are faulty
car drives fine then hits that spot water comes out from top of cap, heater nice and hot when driving
then cools down when stopped or at tick over
let it sit for a while drives fine
weird , I was hoping the guys on here might have had the same problem
thanks for your advice
Post #536705 Fri Sep 29 2017 6:15pm
geoffsnook
That does sound like a water pump issue with what you described
Post #536706 Fri Sep 29 2017 6:33pm
Ratman
That what I was thinking
until head gasket test in water bottle
meaning exhaust gases leaking some where
Post #536725 Fri Sep 29 2017 8:54pm
timmos
Post #540040 Thu Nov 02 2017 10:14pm
Ratman
no not yet
Post #540048 Fri Nov 03 2017 7:34am
