Home > General > instrument cluster stops working intermittent |
There is another member on here who has similar problem, not sure if any cures are posted on it, but may help you, can't see it at the moment but has been running last few days or so.
Thu Sep 21 2017 8:26pm |
iannixon Member Since: 09 Oct 2016 Location: eastbourne Posts: 13 |
Sounds like a problem I'm having at the moment. Do you know when it happens if all your indicators are flashing on the outside and do you first have door locks opening and then message vehicle fault on radio .I lose radio satnav heater and lcd on dash. |
Fri Sep 22 2017 7:41am |
sport2007 Member Since: 10 Feb 2015 Location: bt67 Posts: 41 |
no I just loose all the gauges and the lcd in the instrument cluster and the indicators stop working.
Fri Sep 22 2017 1:07pm |
shutty Member Since: 26 Apr 2008 Location: North West Posts: 2 |
Hi, any luck with this problem, i have exactly the same. I have established that one of the modules dissapears off the canbus when the fault occurs and then comes back on after it resets itself. I am convinced its the instrument cluster, which otherwise seems ok. I have the id of the module in the canbus and i have someone in landrover looking up what it is. (These ids are not available publically from what i can see), but some can be worked out by packet sniffig the Canbus. It may be that there is something else bringing this module down like a faulty wite etc, but all the rest of the canbus appears to continue fine. The integrity of the canbus looks good. |
Wed Nov 15 2017 8:37am |
Yes my problem was resolved with a new instrument cluster. The warranty company originally sent it away to be repaired but it came back with same faults so had to get a new one. All working fine now |
Wed Nov 15 2017 5:36pm |
thanks, I have just about reached the conclusion its the instrument cluster on its way out.
Thu Nov 16 2017 9:04pm |
