Home > Tips & Tricks > Demisting?
TAR
Demisting?
Hi, Can anyone tell me if it is possible to Demist the front screen without the air con on? I have a 2016 hse dynamic. many thanks.
Post #535913 Tue Sep 19 2017 8:13pm
Stuart
Mine has an electrically heated front screen and its an 06. Is that not standard on later ones? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #535914 Tue Sep 19 2017 8:28pm
Tyrefitter
It should have the heated front screen.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #535918 Tue Sep 19 2017 8:52pm
Johnski
As stated above, they are fitted with a heated front screen as standard for that trim, a switch in central console on Mk1s and facelift 2011-2013 also fitted on MK2s (current models) as well. John
Post #535934 Wed Sep 20 2017 12:08am
TAR
Yes I got the heated screen, but was talking about the 'blower', which directs warm air to the windscreen and side vents for the side windows. Is it possible to run this hot, without the air con on?
Post #536028 Wed Sep 20 2017 8:29pm
Johnski
Yes it is, On the 2011-2013 MK1 facelift models and I presume earlier, the fan speed on the A/C & Climate switch, the outer ring turns round and adjusts the fan speed to whatever you want, (even with A/C on you can alter fan speed to), if you turn off A/C & Climate, set your temperature to Hot or 30+C or whatever, this will run hot without said systems switched on. Hope that helps. John
Post #536036 Wed Sep 20 2017 9:11pm
One wonders why one would not just run climate control... 2012 SDV6 - it's missing a couple of cylinders
Post #536041 Wed Sep 20 2017 9:21pm
Johnski
As you say, Thumbs Up I thought similar and always found that was the quickest way if steamed up. Must have a reason why not, and using the recirculate button assists even quicker clearing using climate control. Confused
Post #536042 Wed Sep 20 2017 9:34pm
Eaters
I agree. The climate control will help remove moisture from the air (hence the water you sometimes see dripping underneath the car), so surely the quickest way is to use hot, recycled, climate controlled air. Leave the air con on. Thumbs Up Smile Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #536048 Wed Sep 20 2017 10:59pm
garrycol
Australia
Well you can just turn the Econ button on which turns the aircon compressor off and switch the outlets to to upper dash (defrost) turn the fan up and turn the heat up - bit like the good old days before aircon - the RRS can do it that way.
I always have the climate control on and it does its thing but if cold the system may have the aircon compressor off and the windows can fog up with some heavy breathers in the car but then I just hit the "Prog Defrost" button which brings everything on line a clears the windows in quick time.
If in doubt read the handbook Cool
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #536060 Thu Sep 21 2017 12:55am
SVR fan
prog defrost, there’s a button for that? I have a 2018 SVR - not sure I have seen that?
Post #576661 Thu Mar 07 2019 9:51pm
Think it was only the earlier RRS1 that had the "Econ" button.
Post #576666 Thu Mar 07 2019 10:24pm
SVR fan
Cheers col
Post #576670 Thu Mar 07 2019 11:38pm
Eaters
Prog Defrost on my 2008 RRS turns on both front and rear screen heater elements and directs the a high air flow to the front screen. All at the push of just one button. Robin
Gone:
MGZTT 190 2.5
Post #576676 Fri Mar 08 2019 8:54am
Lynchy
United Kingdom 2007 Range Rover Sport Supercharged HST Java Black
Is the Air Con on constant? Just with the ECON comment there, and the fact im running 12mpg Laughing
Post #621125 Thu Jan 20 2022 12:07pm
