![]() | Home > General > Special program not available |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
Brake light bulbs will cause this
Bulletsaints Member Since: 26 Feb 2017 Location: Southampton Posts: 59 ![]() ![]() ![]() |
Thank you !! So is it dealer only for the brake bulbs or is there a particular brand to buy as I no not all dealers use or stuff as I used to supply main agents with aftermarket parts. Also is there just 1 hdc relay if i was to ask for one and where would i find this ? Thanks again |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
quality bulbs like osram, ring should be fine |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
I had similiar issues when I first owned the car, a new brake light switch and Osram tail/brake bulbs cured the problem until the alternator failed, then the same alarms were occasionally appearing.
Thanks all..... does it matter what make the brake switch is ? Mine was only £1e from mpd |
HDC relay is hardwired in to the engine bay fuse box. I guess that means a new box. That's going to be a non-trivial cost. 2012 SDV6 - it's missing a couple of cylinders
Ok so done brake switch yesterday, just done brake bulbs and both was a little black so replaced with osram bulbs, still getting specai program not available ? One thought tho is I have no high level brake light because I have a none standard tailgate top spoiler !! Should there be a top brake light ? Could this be an issue ?? |
I take it this problem has only just occurred on the disco and the spoiler has been on for a while so that should not cause the issue |
This issue was on the car when I brought it and sò was the spoiler ? |
Next step is to get the faults read then as i assume there are no warning lights on the dash to give you a clue as where to start and no battery issues that your aware off or any spill/fluid marks around the area |
Charged battery over night while still on the car, had a friend use a hand held ßcanner and came up u0100 but trying to sort out getting it on a proper machine |
A missing spoiler brake light won't cause it |
yeah it does need to be read with a proper land rover tool anyone near you got an IID or nanocom you can ask them to read the codes for you i had similar to you except the button's did stuff but used to come up with hdc fault and special programs not available and that was the battery but yours seems a bit more than that do the high range switches and suspension switches work |
Yes high low works fine and so does air suspension, everything works untill the message comes up the terrain light on knob goes out |
