Home > In Car Electronics > Analogue TV tuner |
You have a PM... Malaysia Boleh!
Mon Sep 11 2017 1:03am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Thanks Bobby 2006 RRS S/C CONSTANTLY under modification...
Wed Sep 13 2017 10:21am |
So I have the TV tuner temporarily installed and after 'activating' it in the CCFs using my IID Tool it shows and can be selected on the touch screen, as can the reversing camera which switches automatically.
Tue Sep 19 2017 4:57am |
Most now have a Digital Tuner fitted or dual, as analogue is no longer transmitted. Using the PAL system in the UK, but of course it varies in the different countries model is meant for. SECAM, NTSC etc. John
Tue Sep 19 2017 11:16pm |
So have you fitted the complete range rover tv system or is it an aftermarket setup |
Wed Sep 20 2017 7:19am |
Geoffsnook,
Wed Sep 20 2017 7:24am |
I have roosen dvd players in mine and would like to know if its possible to connect them to the back of my 2012 head unit in my 2005 sport so would need to know what pins to the rear rof the head unit are used for video input as i dont think i can go down the most route or maybe i can |
Wed Sep 20 2017 8:16am |
Hi Geoff,
Wed Sep 20 2017 8:27am |
so as i have an aftermarket system from what you said it should work from fitting an av lead from the tv to the back of the screen but then i would need a way of turning that screen on to the tv channel if i don't fit a tv tuner or maybe take out my tmc modual as the screen has it built in and replace it with a tv modual |
Wed Sep 20 2017 8:52am |
I think the main issues are the trigger via TV module (solved) and then getting the video feed to work either directly into the touch screen or via the TV module. 2006 RRS S/C CONSTANTLY under modification...
Wed Sep 20 2017 8:55am |
so to trigger the tv button you fitted a tv and then edited the ccf maybe worth a go |
Wed Sep 20 2017 8:59am |
Geoff,
Wed Sep 20 2017 9:17am |
Wed Sep 20 2017 9:22am |
Geoff,
Wed Sep 20 2017 9:31am |
