![]() | Home > In Car Electronics > Dipped Beam Bulb Type |
valeo and LR should be the same thing.
azz Member Since: 09 Dec 2014 Location: Worcestershire Posts: 73 ![]() ![]() |
2010 facelift headlights use the D3S. Earlier cars used the D2S. I had exactly the same issue recently. 2010 RRS 3.0 TDV6 - Bali Blue / Ivory Leather / Extended Leather / TV / Rear Entertainment / Privacy Glass / Timed Climate
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Spot on Azz |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
The bulb type is shown on the headlight itself. There is a moulded-in panel on the top surface with info about the lights, who make them, E- numbers etc. It should have the xenon bulb on there too. On mine, it's at the outer end of the panel. Just visible here at the far right - it's easier to read on the real thing. This is an OEM Hella unit (hence the scrubbed out LR logo!)
RRSTDV8 - Well I never knew that |
I just went out in the rain to take that snap! |
Thanks for all the help got it sorted.
I think fog lights, light up the road quite well, depending how far your going and if you know the route well |
Andy K,
