Home > Faults & Fixes > Central locking problem, horn beeps when I press the key fob
R1CHD
United Kingdom 2005 Range Rover Sport TDV6 SE Java Black
Good Morning
For some reason when I park my car up and get out press the key fob to lock the car the horn just sounds and the car will not lock, when sitting in the car the doors lock ok but with the drivers door closed a message on the dash says drivers door open! Is there a way to over ride this so I can lock my car?
Thanks [/url]
Post #535078 Tue Sep 12 2017 11:49am
Scrumpy
Not sure this helps you much but the horn sounding is an audible warning to let you know that something is not shut properly and therefore the system can't arm.
Might sound dumb but have you gone round and opened and shut every single door, boot and bonnet just in case one of the sensors is reading something.
It could be something as simple as the boot not shut properly or the bonnet.
Worth a try 2016 RRS SVR Estoril Blue
Post #535086 Tue Sep 12 2017 1:22pm
R1CHD
Hi
Yeah I've double checked all doors the problem seems to be with the drivers door not seeing that it's closed it seems if I slam it hard it then locks ok so I'm guessing door lock mechanism fault or is there a simple fix / over ride?
Post #535088 Tue Sep 12 2017 2:00pm
The door lock needs changing. Had this on mine last year. 2012 SDV6 - it's missing a couple of cylinders
Post #535091 Tue Sep 12 2017 2:55pm
