Home > General > MOT & Parking Brake
nebc100
Luxembourg 2008 Range Rover Sport TDV6 HSE Java Black
MOT & Parking Brake
I am REALLY upset!!
I bought my new (to me) RRS on Monday. I had booked it in to my MOT station to get it registered. Everything was going well until the brake test.
The chap got it, drove on to the rollers, and front brakes were fine.
Back brakes... fine
Handbrake... He fiddled with the button, on, off, on, off, on, off, all with the wheels turning, and suddenly SSSCCRREEAACCHH!!!!! One back wheel COMPLETELY blocked.
Now when we try to take the EPB off, there is this loud scraping screeching noise, and then flashing EPB light on the dashboard.
THEY HAVE BROKEN MY EPB!!!!!!!!!!!
They won't even accept responsibility!!
Has anyone had this type of thing happen to them?
I know that the D3 had big problems with the EPB at the beginning, but have these problems been resolved?
Should I simply put it in park instead of using the EPB?
Post #534813 Fri Sep 08 2017 7:07pm
geoffsnook
Rear brakes sound like they need adjustment was it a 4 whel brake machine as normally they take them for a run around the block with a mobile brake machine Thumbs Up
Post #534814 Fri Sep 08 2017 7:10pm
DrRob
Bunch of pr8cks Censored Visitor from fullfatrr.com
Post #534815 Fri Sep 08 2017 7:12pm
nebc100
No... it is a two wheel device that spins the wheels in opposite directions and then only test one wheel at a time.
At the moment the car is at a local garage, and they are going to look at it at the beginning of the week.
I have ordered a new "module" because I think that the cogs inside have had their teeth stripped (sadly!!).
I find it amazing that they can simply force people to test their EPB this way when it can break the system.
Post #534819 Fri Sep 08 2017 7:17pm
Tyrefitter
WHY didn't the tester use the decelerometer brake test.? I don't know of a roller brake tester that does constant 4 wheel drives.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #534824 Fri Sep 08 2017 7:54pm
nebc100
Sadly, they test ALL vehicles here this way. They don't ever test using a Decelerometer.
Do you happen to know if there is any documentation from LR that say they should not test the brakes in this way?
I have been told that i can send thr invoice to them, and if i can show that the damage was cause by their mistake, then their insurance will cover the bill.
Post #534825 Fri Sep 08 2017 8:00pm
Tyrefitter
Here you go,,have read.
http://mtaeta.info/thread/3194/4x4-brake-test
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #534827 Fri Sep 08 2017 8:02pm
nebc100
The rollers they use here rotate the two wheels in oposite directions, as it stated in that link.
Does that mean that their roller system is in fact OK for the LR?
Post #534828 Fri Sep 08 2017 8:08pm
Tyrefitter
Ive NEVER done RRS or FFRR in the rollers,,you can do the park brake in them but it has to be done correctly so not to do damage.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #534829 Fri Sep 08 2017 8:14pm
Oldandconfused
There are set procedures for testin an EPB on a 4x4.
Have a look at this;
https://www.disco3.co.uk/forum/topic34675.html
Unless the tester is really confident, most use an old school Tapley meter.
I can't comment on the likelihood of your tester damaging your EPB, but I suggest you carry on googling.
Post #534831 Fri Sep 08 2017 8:30pm
nebc100
Well.... the brakes have been replaced. The electronic module has been replaced.
When we were doing the work, we discovered that the rear brake pipes were VERY badly corroded, so off they came. We cut them half way along the length of the car, and fitted new pipes.
We are halfway through changing the timing belt. We in fact discovered that the belt has been replaced already at some point, which is good to know, but we are going to replace it again anyway. Better to be safe, and since we have the cover off, why not.
So... she should be finished tomorrow, and then I have an appointment for the MOT on Friday.
Fingers crossed... I hope everything will be OK.
Post #536021 Wed Sep 20 2017 5:58pm
Johnski
Sound as if you are very busy there.
I have been told you must be very careful doing brake tests with 4x4s and Electronic Park Brake, on rolling roads unless operator knows what they are doing. Depending on speed you can cause damage to, and I hope this hasn't happened here. John
Post #536043 Wed Sep 20 2017 8:43pm
garrycol
Australia
nebc100 you dont list what car you have but you do mention timing belt so I assume a TDV6 - if a 2.7, did you check you have the later oil pump - shame to have done all that work and have the old oil pump still on the car.
Also given that the EPB only applies the drums to hold the car when parked but when used as an emergency brake when the car is moving it does not work the drums but applies the entire braking system (I am not sure what speed this kicks in but it is low) I am surprised they are testing the EPB on a rolling road.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #536061 Thu Sep 21 2017 12:00am
