Home > General > MOT & Parking Brake |
nebc100 Member Since: 27 Aug 2017 Location: Altlinster Posts: 113 |
I am REALLY upset!!
Fri Sep 08 2017 7:07pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Bunch of pr8cks Visitor from fullfatrr.com
Fri Sep 08 2017 7:12pm |
No... it is a two wheel device that spins the wheels in opposite directions and then only test one wheel at a time. At the moment the car is at a local garage, and they are going to look at it at the beginning of the week. I have ordered a new "module" because I think that the cogs inside have had their teeth stripped (sadly!!). I find it amazing that they can simply force people to test their EPB this way when it can break the system. |
Fri Sep 08 2017 7:17pm |
WHY didn't the tester use the decelerometer brake test.? I don't know of a roller brake tester that does constant 4 wheel drives.
Fri Sep 08 2017 7:54pm |
Sadly, they test ALL vehicles here this way. They don't ever test using a Decelerometer.
Fri Sep 08 2017 8:00pm |
Here you go,,have read.
Fri Sep 08 2017 8:02pm |
The rollers they use here rotate the two wheels in oposite directions, as it stated in that link.
Fri Sep 08 2017 8:08pm |
Ive NEVER done RRS or FFRR in the rollers,,you can do the park brake in them but it has to be done correctly so not to do damage.
Fri Sep 08 2017 8:14pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
There are set procedures for testin an EPB on a 4x4.
Fri Sep 08 2017 8:30pm |
Well.... the brakes have been replaced. The electronic module has been replaced.
Wed Sep 20 2017 5:58pm |
Sound as if you are very busy there.
Wed Sep 20 2017 8:43pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
nebc100 you dont list what car you have but you do mention timing belt so I assume a TDV6 - if a 2.7, did you check you have the later oil pump - shame to have done all that work and have the old oil pump still on the car.
Thu Sep 21 2017 12:00am |
