![]() | Home > Faults & Fixes > Air suspension fault - sitting on bump stops |
Don't drive it on bump stops.
davidsherry33l Member Since: 12 Dec 2015 Location: hartlepool Posts: 23 ![]() ![]() ![]() |
just called the RAC let them have a look at it , I would doubt they can fix it but you never know...
Sorry to hear your problems.
hi ,
RAC bloke thinks I'm needing a new compressor .....
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
I suspect you have a small air leak somewhere in the system, the car should not be on bump stops after just 3 weeks. The compressor has probably worn out because it is overworking to compensate for the leak. My son had a similar issue with his L322. |
See if rac will take it to Disco Mikey in Dundee : |
If you have the LR assistance, either original 2 year warranty or full annual extension up to 10 years 100,000 miles, they will take your car to the dealer of choice, unlike normal AA, Green Flag and RAC membership. They took mine 170 miles from Wales to Pickering to get sorted. Very impressed. |
