![]() | Home > Faults & Fixes > Transmission fault lost communication/missing message |
Simms Member Since: 23 Jan 2017 Location: Shefford Posts: 23 ![]() ![]() ![]() |
Hi ladies & Gentlemen,
Have you checked all the usual suspects; battery (as already suggested), brake light switch, brake light bulbs?
Thanks Paddi & Geoffsnook,
This is the "limp home mode" and is the gearbox doing what it should for the fault it has encountered. The gearbox selector switch (the one that tells the gearbox to be in PRNDL), along with the TCM, is in the mechatronic unit within the gearbox. Sounds like you need to talk to a ZF specialist if the LR dealer wouldn't help. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Don't know if this is any help:
Hi RRSTDV8,
11.7 volts is very low - try fitting a new battery as this may be the cause. Memory is a bit hazy but I think there is a connector plug to the gearbox and some earthing points to clean up. You just have to remove the plastic undertray to gain access. The steering angle sensor is attached to the steering column but you don't need to touch it - just have someone with the correct diagnostic kit to calibrate it. Brake light switch and bulbs are inexpensive and an easy DIY; There are guides on the procedures if you search this site and the Disco 3 site. Edit: Just discovered that your location is Bedfordshire so you are quite close to Landers Garage in Houghton Regis. They are a Land Rover independent specialist. Unlike most garages they are friendly, helpful, extremely knowledgeable and don't try to rip you off. 2008 MY Java Black TDV8 HSE ![]() |
Cheers Paddi,
Well, after four days on shift, 10 mls A roads (50-60mph) one way.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
It's a shot in the dark but have you tried resetting the gearbox adaptions/updating the software ?
Hi Socast,
When the box is hot the oil is thinner and the valve block itself will also expand slightly, however not all components will expand at the same rate or to the same degree, so with age related wear, heat expansion and heat thinned/degraded oil; tolerances aren't as close as they should be hence the issues you're seeing.
Hi Socast,
Certainly a good idea to go along with the gearbox fluid flush. Considering that doing it yourself by dropping the sump is a major and messy PIA fraught with all sorts of difficulties (it is a struggle to get the sump off because the cross member is in the way; need to change the loom connection sleeve; need a IR temp probe to check gearbox temp when filling with engine running etc.) I'd recommend you look into having it flushed the non-invasive way by somewhere with the special equipment. The nearest to us is JGS 4x4 a site sponsor. Not used by me but a few forum members have given very positive feedback.
