![]() | Home > Wheels & Tyres > tyres |
Ozziev1980 Member Since: 11 Feb 2014 Location: London Posts: 15 ![]() ![]() |
turbotim Member Since: 06 Feb 2017 Location: Kent Posts: 14 ![]() ![]() ![]() |
I am probably going to do something similar,
Sorted |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
How does it affect the speedo, odometer, etc. (if at all)? |
Done |
Are you sure you have those figures the right way round? as when I changed to 45 profile the speedo read 30 mph where as the actual road speed was betwen 31/32 mph and it was the same on both my sports. As a higher profile in effect makes a larger diameter wheel, would this not cause the speedo to read slow.
TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 127 ![]() ![]() ![]() |
Didn't make much difference to speedo reading when I swapped mine. Certainly not enough to be concerned about. I found that compared with gps the speedo was reading slightly over true speed, changing to 275/45 got it a bit closer. Much smoother ride though. I also think the larger side wall looks better on the car. -----------------------------------------------
warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234 ![]() ![]() ![]() |
Funnily enough, looked air our 19 inch wheels tonight and they are actually 20 inch wheels fitted Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4 |
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 ![]() ![]() ![]() |
Sorry to bump an oldish thread, what pressure are you guys running in yours?
Hi
Thanks for the reply |
More air same pressure was my advice.
Cheers, I'll leave them as they are and see how I go:). On the topic of this thread, they certainly are so much more comfortable! 2006 Java Black HST Supercharged |
dover Member Since: 22 Dec 2013 Location: Waipu Northland NZ Posts: 15 ![]() ![]() ![]() |
Best move I made was to change to 45 profile ! Much better ride |
