Home > Wheels & Tyres > tyres
Ozziev1980
tyres
Post #522027 Mon Mar 27 2017 12:59pm
JOCK55
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
The Michelin Lats are great summer road tyres, only problem is that they are USELESS in mud and snow! However, seeing as you live in London, they are unlikely to see any of this.
Old Jock 2018 (MY19) Jaguar F-Pace R-Sport 300PS Petrol in Caesium Blue with many bells and whistles.
2015 RRS HSE SDV6 Firenze Red with Santorini Panoramic Glass Roof, gone but not forgotten.
Post #522034 Mon Mar 27 2017 1:22pm
turbotim
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
I am probably going to do something similar,
How much of the improvement do you think is down to a better quality tyre,
And how much is down to the higher profile ?
Post #522260 Wed Mar 29 2017 6:08pm
Ozziev1980
Sorted
Post #522400 Fri Mar 31 2017 9:38am
donny dog
How does it affect the speedo, odometer, etc. (if at all)?
Post #522402 Fri Mar 31 2017 9:46am
Ozziev1980
Done
Post #522416 Fri Mar 31 2017 12:04pm
Are you sure you have those figures the right way round? as when I changed to 45 profile the speedo read 30 mph where as the actual road speed was betwen 31/32 mph and it was the same on both my sports. As a higher profile in effect makes a larger diameter wheel, would this not cause the speedo to read slow.
Chers
Post #522475 Fri Mar 31 2017 9:37pm
TPS
Didn't make much difference to speedo reading when I swapped mine. Certainly not enough to be concerned about. I found that compared with gps the speedo was reading slightly over true speed, changing to 275/45 got it a bit closer. Much smoother ride though. I also think the larger side wall looks better on the car. -----------------------------------------------
RRS SDV6 HSE MY2012 Orkney grey, Oxford leather Ivory seats Ebony carpet, Anigre wood trim, enhanced design pack.
Post #522480 Fri Mar 31 2017 10:17pm
warkman
England 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Funnily enough, looked air our 19 inch wheels tonight and they are actually 20 inch wheels fitted Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #522481 Fri Mar 31 2017 10:23pm
TomTerrain
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Sorry to bump an oldish thread, what pressure are you guys running in yours?
I've just got a set of 275/45/20's in the goodyear eagle F1's. Set them to 36 psi front, 39 rear. 2006 Java Black HST Supercharged
Post #532008 Fri Aug 04 2017 7:05am
TPS
Hi
I run 275/45/20 Pirelli scorpion but as it's generally just me in the car I run 33 front and 36 rear as per the label, making sure I check pressures only when tyres are cold and rested. -----------------------------------------------
Post #532009 Fri Aug 04 2017 8:26am
TomTerrain
Thanks for the reply Thumbs Up
I thought a bigger tyre would want more pressure?
Post #532010 Fri Aug 04 2017 8:44am
TPS
More air same pressure was my advice.
Rides well on those pressures. Of course once running they warm up and pressures increase. I have TPMS and after a good run they generally reach 36 front and 40 rear in any case. -----------------------------------------------
Post #532016 Fri Aug 04 2017 10:22am
TomTerrain
Cheers, I'll leave them as they are and see how I go:). On the topic of this thread, they certainly are so much more comfortable! 2006 Java Black HST Supercharged
Post #532030 Fri Aug 04 2017 3:21pm
dover
New Zealand 2012 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
Best move I made was to change to 45 profile ! Much better ride Thumbs Up 2012 RRS. Orkney Grey
Post #533101 Thu Aug 17 2017 9:53pm
