Home > In Car Electronics > 2008 RRS radio upgrade question
savi18
New Zealand
Have searched old and new post but cannot find the answer i want, i have a 2008 RRS S with just the standard stereo and not the Hardon Kardon system, does the standard stereo have the fiber optics as on youtube there is a radio upgrade with fitting kit and appears not to have fiber optics, it was plug and play and no cutting of wires, all done in 30 mins, i want to upgrade my radio and keep the top nav screen, Cheers
Post #530895 Sat Jul 22 2017 3:09am
savi18
New Zealand
Have found this
I have nothing on the speakers and have looked at the build details of my RRS from my local Dealers and all it says is standard radio fitted, To identify if you have a factory-amplified audio system, you can check the vehicle in a number of ways. Some vehicles will have clear markings on the speaker grills indicating the presence of an upgraded audio system. You can also check with the original order notes/invoice from when the car was purchased from the factory, the upgraded sound system with an amplifier would show on the options list. If unsure, you can call your local dealer with your vehicles chassis number and ask them to check if the vehicle was manufactured with an amplified audio system. what do you think
Post #530980 Sun Jul 23 2017 12:02am
geoffsnook
just look under the front seat and see if you have a amp there or take out the head unit and see if there is a fibre optic cable plugged in to the back of it Thumbs Up
Post #530987 Sun Jul 23 2017 6:54am
The fact that you say you have navigation sounds like you have optical fibre and need to do something different to keep the factory nav working if that is what you want?
Post #531002 Sun Jul 23 2017 9:34am
geoffsnook
Missed the part where he said he had navigation Embarassed
Post #531004 Sun Jul 23 2017 10:10am
Socast
http://www.caraudiodirect.co.uk/install-ad...itting-kit
Post #531097 Mon Jul 24 2017 12:31pm
savi18
New Zealand
Just looked under drivers seat and no Amp, so i am guessing there is no Amp fitted meaning no fibre optics cable to radio, what do you think.
Post #531237 Wed Jul 26 2017 5:56am
geoffsnook
Just remove the radio to be sure that there is no orange cable going to the back of head Unit but no amp should mean no nfibre optic as you don't have sat nav fitted do you ?
Post #531239 Wed Jul 26 2017 6:31am
savi18
New Zealand
Yep i do have sat nav, best thing to do is remove the radio this wk end have have a look to see if there is an Orange cable attached, will update if weather is not pouring down, Cheers
Post #531265 Wed Jul 26 2017 9:43am
geoffsnook
If you have sat nav you proberly have Harmon kardon system with fibre optics but remove radio and check Thumbs Up
Post #531277 Wed Jul 26 2017 11:55am
savi18
New Zealand
Have just removed radio and does have the orange fiber optics cables, hoping it did not as radio upgrade wound have been a lot simpler, just have to look for radio upgrade with the cables and patch leads, do want to keep top sat nav though so now searching for suppliers included the links posted above.
Post #531567 Sat Jul 29 2017 1:18am
savi18
New Zealand
Can not find anything to say its an Harmon Kardon, think it's a standard radio with fiber optics.
Post #531627 Sat Jul 29 2017 8:24pm
With all those green wires? In the back there may not be an amp.
However you probably need it for the sat Nav
Post #531628 Sat Jul 29 2017 8:27pm
savi18
New Zealand
You might be right(no amp) as can not find the amp location if fitted, no amp under the drivers seat either. Cheers
Post #531629 Sat Jul 29 2017 8:39pm
Eaters
Does this help? Mine is Harmon Kardon system I know cos it says so on the door speakers Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #531632 Sat Jul 29 2017 10:49pm
