Home > General > Lifters
Bullnogger
England 2007 Range Rover Sport TDV6 HSE Java Black
Lifters
Hi all can anyone tell me or point me
In the right direction of how to remove
The driver side cover to the lifters
need to have a look at them got a tap tap noise
Hopefully shouldn't be to hard to remove cover
read Haynes manual but that is removing everything
On the way to covers
Just wonderd if there was an easier way
As it says remove bulkhead harness to get to bolts on coolant crossover pipe
Or is that the only way
2.7 Range Rover sport
many thanks for any replys
Post #530958 Sat Jul 22 2017 5:46pm
It's not easy although I don't think the loom needs to move
Fuel rail off and it's mounting bracket.
Injectors out (twist a bit)
Y inlet off
Oh and the bloody cambelt cover as there is a bolt under there
Black fuel pipes in the way and coolant pipe as you say
Post #530960 Sat Jul 22 2017 5:53pm
of course to get the lifters out, you need to remove the cambelt and cams
oil pumps are a nightmare for breaking on the cambelt tensioner once messed with (on 2007 models) so would need a new oil pump.
All a lot of commitment and expense
Post #531003 Sun Jul 23 2017 9:38am
Disco_Mikey
And let's not forget the special tools to remove and refit the rear cam seal...
Post #531005 Sun Jul 23 2017 10:41am
It's the drivers side.
I was thinking or the crank seal though !
Post #531006 Sun Jul 23 2017 10:49am
Disco_Mikey
Ah yes Embarassed
Though why you would only do half a set...
Post #531016 Sun Jul 23 2017 12:51pm
Bullnogger
Thanks for replies
Haveing read what you have posted
and realiseing what it entails to access lifters
I think that's a job for the indie
What are your thoughts on doing an
Engine flush to see if that will quieten lifters down
Any recommendation on what flush to use
Thanks once again for your replies and any advice
Post #531080 Mon Jul 24 2017 5:43am
Disco_Mikey
Get it nice and hot, drain the oil, remove the filter and let drain overnight
Refill with good quality oil and an OEM or genuine filter Thumbs Up
Post #531115 Mon Jul 24 2017 5:04pm
Bullnogger
Disco mikey
Thank you for advise very much appreciated
I've been useing triple qx 5/30 fully synthetic
Do you think that oil is ok
If not what would be best oil to use
That is what shop said was right oil
For sport
Thanks once again
Post #531119 Mon Jul 24 2017 5:39pm
