Home > General > Rrs 3.6 tdv8 |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
Kent's quite a big county and my suggestion is not even for Kent but if you are near the Sussex border, the I'd give Groombridges in Heathfield a ring. Won't be much good to you if you're in Broadstairs however.
Mon Jul 17 2017 9:53pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
When was the fuel filter last changed ? Might be a good place to start by renewing.. 2008 G4 RRSport TDV8 current
Mon Jul 17 2017 11:00pm |
Past91rrs09 Member Since: 05 May 2017 Location: Kent Posts: 9 |
Thanks I'm in sheerness Kent, will try and get in touch with Geoff.
Tue Jul 18 2017 2:35pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
If the suspension was getting involved in your problem I'd expect a suitable error code to be stored.
Tue Jul 18 2017 3:14pm |
Only visual things I can see is the intercooler looks as if it leaking I've replace the top hoses and front a read ace anti roll bars are leaking every so often it leans toward the drivers side like it thinks it going into a bend/corner I've put some pictures of this I've also read somewhere there's a sensor that detects g force on accelerating and cornering that can become faulty ? |
Thu Jul 20 2017 2:29pm |
Is this a new purchase or have you had it a while?
Thu Jul 20 2017 7:40pm |
