![]() | Home > General > Chopped in the 2.7 for a 5.0 |
Creaking suspension - were you stopped with the parking brake on when this happened? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 ![]() ![]() ![]() |
Hi Tim,
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
5.0 Supercharged or normally aspirated? I just bought a 2010 5.0 normally aspirated. I have had it nearly a week. I also came (a long time ago) from pre facelift 2009 2.7TDV6. The 5.0 V8 is quite an engine, I agree.
BKHK, We don't get the NA 5ltr in the UK, only 3.0lt S/C,5ltr S/C or SVR on the petrol front
Tim,
Enjoy ![]() |
Tim, yes the NA 5.0 seems very rare, more common in the USA I think.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
If the squeak is at the rear then it could be the hub bushes. These are the ones that connect the rear upright to the wishbones. Mine has a had a couple done. The squeak is pretty loud and very noticeable at slow speed.
Squeak or creak? I've had the squeaks before on the 2.7, had to get the bushes done twice in 14 months on that one.
Another blast for 30 mins and I'm pretty sure it's bushes. Started fine and at the end of the drive it was creaking when I turned slowly, up onto the drive etc. Same sort of noise as the 2.7 when the bushes were gone on that, but less squeaky. Brakes pretty squeaky too by the time I got home. Irritating. I'll see if I can get it looked at by James French tomorrow. Other than that, it's spot on! |
Front lower arm bushes confirmed. Annoying but being done on Monday by a local garage. On the plus side this car is 15 quid a month cheaper to insure. No idea how that works out, but I'll take it! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Not uncommon at least on a S/C. L/R do what they call a Anti Squeal Brake Pad now for the RRS2 whether it works or not I don't know or if they fit the RRS1 either. Funnily enough James French fitted new Rear Discs and Pads for me, genuine L/R parts which I supplied, never been any problem since. Never had any problems with the Fronts. Cheers Col |
How much were they, Col? I'll need to get the noise sorted fairly soon as it's so annoying if you've got the windows open. Did you just get them from eBay or something? |
