Home > Maintenance & Modifications > Flappy paddles
geoffsnook
Flappy paddles
Hi everyone has anyone fitted the flappy paddles to there sport i have the heated wheel and was wondering what it would cost and what needs to be done editing wise thanks Thumbs Up
Post #529573 Tue Jul 04 2017 6:41pm
DrRob
Never use mine but I guess it's a personal thing Whistle Thumbs Up Visitor from fullfatrr.com
Post #529575 Tue Jul 04 2017 7:20pm
geoffsnook
I probably would not either but would just like to have them if you know what i mean Rolling with laughter Thumbs Up
Post #529577 Tue Jul 04 2017 7:26pm
DrRob
Thumbs Up Rolling with laughter Thumbs Up Visitor from fullfatrr.com
Post #529585 Tue Jul 04 2017 8:12pm
Only time I've used them on my current sport is accidentally when turning steering wheel. Rolling with laughter
I did fit them to a previous pre-facelift 09 sport for something to do, used all brand new parts including heated steering wheel etc. cost about 1k. It's not to difficult to do but the paddles will only work if the transmission is in sports mode.
If you already have a heated wheel fitted then it's only the circuit boards you need from Blackbox Solutions, so should be around couple of hundred pounds would have thought.
Post #529586 Tue Jul 04 2017 8:34pm
Smarttech
I had a E46 M3 with paddles and used them permanently and thought I would use them in the Sport but other than a couple of times when I first got the car I've never used them since and think they are a bit pointless and n the Range Rover! 2017 SVR. SVO Scafell grey Ebony interior
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #529592 Tue Jul 04 2017 10:07pm
Johnski
Strange, I generally use my Paddles much of the time, also with box in Sports mode, except on motorways, as once in 8th gear no need to use them just hit cruise and relax instead. John
Post #529594 Tue Jul 04 2017 11:38pm
Smarttech
I think it's down to how quiet the sport is and being diesel it runs out of revs at about 4K rpm so catches me out as I find you need to watch the rev counter to change at the right time. With the M3 you could hear when you needed to change plus revving to 8k rpm you never ran out of revs before you pulled the up paddle.
Maybe I just need more practice ! 2017 SVR. SVO Scafell grey Ebony interior
Post #529595 Wed Jul 05 2017 5:43am
Buckster
I use mine! Great for selecting a gear for when you want to overtake instead of waiting for kickdown or the box to sort itself out.
And used offroad all the time. I put it in Sport and use paddles in manual. If left in auto in low box it tends to hold gears to long which starts to Censored me off after a while. And i cant stand hill decent so the only way to get to 1st gear on decents is via the paddles.
I really cant understand why people dont use them!! Whistle 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #529599 Wed Jul 05 2017 6:32am
Tim in Scotland
I think people don't use them because, especially with the 306bhp SDV6, the torque is so good that they aren't really necessary and they are happy not to drive their Sport as a sports car. Up to March last year I used to use paddles and S mode on road a lot but after the Gearbox ECU software remap that was a TSB was done at the service I have only ever used the paddles in "Command shift" (S+Low ratio) off-roading. Like you I also prefer to use engine braking in 1st offroad rather than HDC I also don't like the way the gearbox tends to shift up a gear or two when driven in Auto mode offroad on a downslope thus reducing the engine-braking effect. I do use HDC on wet grass on steep downslope runs and rockcrawling. HDC still eats pads and shoes if you leave it on all the time offroad. At least with LR's TR systems you have the option to have them on or off, although with Auto TR it is becoming harder to drive offroad "the old fashioned way". In my car I have to leave it in the "on road/ normal" setting but in low box to use the car as I drive my non-electronics equipped Defender, any other way either requires a TR program to be selected or AutoTR2 (the selector in the pressed down position which is the default in L494) and it is quite unnerving to get the warning "System Optimising" on the screen while the computer decides which program it is going to set when you are in a tricky situtation. I would prefer not to know the system was optimising and just assume that it is operating seamlessly ( which it does anyway). "System Optimising" tends to make you think that the system is trying out various modes before deciding the best setting - that sort of "in limbo" setting where you think no programmes are selected! I know that it retains the pre-optimising setting engaged but I have had quite experienced offroad drivers in the car who have been flummoxed by the warning and they cannot understand a computer that can "multi-task" the settings. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #529600 Wed Jul 05 2017 7:44am
Lyonhead
Wales
I tend to use the paddles quite a bit, especially when the car holds the gear too long for my liking. Maybe this is why my MPG is quite a lot better than most people have stated they get on here. On motorways there is no real need but in town driving and especially first thing in the morning I tend to use them. When you want the car to be a bit lively, sport mode and dynamic then I use the paddles all the time just to give it the odd blast Thumbs Up
Post #529608 Wed Jul 05 2017 9:42am
geoffsnook
Thanks for the replies guys i have a supercharged sport so plenty of grunt and col already have the heated wheel fitted and all the add ons except the paddles so would need only the 120 euro part from black box +paddles so its just how much i WANT them or how much i need them Rolling with laughter Rolling with laughter
Post #529632 Wed Jul 05 2017 5:42pm
