![]() | Home > My Range Rover Sport > My first Range Rover. |
StateOfPlay Member Since: 24 Jun 2017 Location: Biggleswade Posts: 26 ![]() ![]() |
I am so pleased I took the plunge, many friends telling me it was too extravagant a purchase, too costly to run etc. But they all agree, it is a stunning looking motor.
robmeister1969 Member Since: 24 May 2008 Location: Surrey Posts: 125 ![]() ![]() ![]() |
The wobble at a narrow speed range, if it's like a vibration, could also be the central bearing assembly to the propshaft from what I understand. Not a particularly expensive job to rectify from what I've read. 2005 RRS First Edition Supercharged
Ah right, I didn't know if this would be covered under the LR warranty as it is just a slight wobble at 70 mph, noticed it more in France as speed limit was 80 MPH.
Could it be a buckled wheel |
I took it to my local garage just before I went on a long trip to check, they looked at all 4 wheels, balanced them, but said they couldn't work out why there was a wheel wobble as the car reached 70mph.
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
Trivial or not, I would approach the garage/LR on the assumption that it was a warranty issue - let them try to prove otherwise. (Plus, have a good look at the 'small print' in the warranty first). |
Take it back and say call me when it's fixed and oh your paying for it LR. Use that warranty to its max! Mine has been back a few times and all done under warranty. Renewed the 2 year warranty last month thankfully as it's back in for another oil leak. Don't ever ever accept that you pay! Visitor from fullfatrr.com
Mine is a 2011, had to have a new steering rack under approver warranty due to wheel vibration. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Should add, there are some TSB's in my Gallery ref Wheel shimmy etc |
Ferret15 Member Since: 11 Jun 2017 Location: Somerset Posts: 31 ![]() ![]() ![]() |
My wobble came down to when the previous owner put on none standard wheels, they never put on the wheel spacer. Ever since I've had no wobble. |
Mine only vibrates when I get to 70 MPH, and it can sometimes be very slight, or sometimes more severe depending on the road I am on. What was it you were experiencing prior to the new steering rack? Cheers. |
Use the warranty |
Yes, I'm booking it in. |
