![]() | Home > General > Engine Super Quiet in P but not in D |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
should be something wrong in your drive line. start with the gearbox RRS 3.0 SDV6 HSE Lux
:r |
csharper Member Since: 20 Jun 2017 Location: Lancashire Posts: 11 ![]() ![]() ![]() |
Thanks for the reply, I really need to upload a sound snippet to give more information I will try to do it tonight or tomorrow |
Have you checked for loose heat shields ? Do you get a judder threw the car on light acceleration if so could be the torque converter. A few people have described hearing a rattle on the D3 site under similar conditions to what your describing.. 2008 G4 RRSport TDV8 current
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
What engine do you have? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Hi its the 2.7TD v6 |
Have you the car long, has it just started doing this ? 2008 G4 RRSport TDV8 current
Well, the revs will sit down a touch when you put it in "D", could be a vibration-induced resonance somewhere - heatshields as mentioned is a good place to start I suppose. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
