Home > Maintenance & Modifications > Slight loss of coolant |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
Check your oil filler for signs of a cream coloured residue which could indicate coolant is getting into the oil. |
Sun Jun 11 2017 6:39pm |
warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234 |
No, no emulsification in the oil cap area Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4 |
Sun Jun 11 2017 8:07pm |
dalmat Member Since: 09 Sep 2015 Location: Split Posts: 36 |
Maybe water outlet connection #1357091 (known thing) located in the middle of block, bellow intake "Y" connection. I had mine replaced after finding that coolant level was going down slowly with no visible leakage. In my case one of rubber O-rings was problem but I put new part on place to keep peace of mind. |
Mon Jun 12 2017 6:49am |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
DALMAT,
Mon Jun 12 2017 2:14pm |
Warkman, My isssue was somewhat similar. I never really check my fluids but 2 months ago without any suspicions I had a look at my coolant level and noticed that it was below minimum. I filled it up and have been keeping an eye on it since. So far no real change but I'll continue watching it closely with all these +30 heat warnings we are getting. Has your coolant level dramatically dropped since you filled it back up? |
Mon Jun 12 2017 2:32pm |
Either buy a pressure tester or have a garage pressure test it for you. That should at least reveal if you have a leak or not.
Mon Jun 12 2017 3:39pm |
CANROVER
Tue Jun 13 2017 6:53am |
Thanks Dalmat,
Wed Jun 14 2017 11:24am |
CAN
Thu Jun 15 2017 7:40am |
Very True,
Thu Jun 15 2017 10:53am |
