![]() | Home > Technical > iid Tool Question |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Yes it can.
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Thanks for the confirmation Barryp |
ReaR is meant to be a bit higher.
Range Rover Sport L320 Front 461mm Rear 465mm
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 ![]() ![]() ![]() |
Someone was selling a used iid on the disco forum for £300 last week, worth a look to see if it's still there.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
There is a +/- 12mm Front and +/- 13mm Rear tolerance on standard ride height so I guess theoretically worst case scenario could be a 29mm difference between front and rear heights and still be within spec. Would look a bit odd though I would imagine |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 203 ![]() ![]() ![]() |
I bought a BT one last week for peace of mind along with a suspension adjustment and timed heating . Makes sense to have the full tool. 2018 Telsa MS
Got the tape measure out today and measured the wheels from floor to arch while car is in access mode and both rears measure exactly the same at 77 cm but there is a difference on the front. Passenger side measures at 75 cm so 2 cm less than rear but drivers one measures 73 cm so a 2 cm gap between the passenger side wheel, im guessing the passenger side could be right as the drivers side is very close to bump stop, this could be the reason why it wants to go into extended mode most of the time when trying to lower to access mode and have the red flashing light on the drivers wheel on the 4x4 screen but only flashes red when in access mode?
Mine sits lop sided at the front in access mode. I assume it's just kinda on bump stops in access mode, and calibration has little to do with it. A red bar is not unknown in access mode. Ignore.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
But if you get out and leave the door open, if your a tad heavy then the drivers side will rise but leaving the door open will prevent the car levelling (thinking of P38 theory here)?
RRS L320 and L494 suspension stops both lowering and raising when a door is opened - I continually have to remind passengers to let the car get to access height before they open a door otherwise they will have a large drop to the ground...... I refuse to fit ugly side steps. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
True.
