![]() | Home > Faults & Fixes > Multiple fault readings: transmission fault, engine system.. |
How old is your battery?
Simon_scott_wilson1979 Member Since: 30 May 2017 Location: Stratford-upon-Avon Posts: 4 ![]() ![]() ![]() |
Only changed the battery about three months ago when the cold weather pushed it over the edge and it let me down. Is a pretty high spec battery and has been fine up until now......still think it's worth getting it drop checked?
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Getting codes read early seems to be the common advice on this forum before you start sending good money after bad chasing faults that aren't there. Haven't got one myself but if you are handy with spanners etc and have the basic facilities, then the wisdom here seems to be to buy a good quality reader. If not a trip to your local Indie? Robin
[quote="Simon_scott_wilson1979"]Only changed the battery about three months ago
According to the icon in the name box he has a 2007 TDv6 HSE in Izmir Blue 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 ![]() ![]() ![]() |
Its probably the battery, put it on charge overnight and see if it cheers up. |
Might also be worth getting the alternator checked out that it is working properly 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Update -
