Home > Technical > Dynamic |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
2.5 litre capacity. Bleeding done with plug in magic boxes although fairly sure Disco_Mikey will have a simpler method. 2012 SDV6 - it's missing a couple of cylinders
Thu Jun 01 2017 11:35am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Thanks RRRSTDV8 just found a how to showing both diag plug in to cycle the valves but also a pressure bleeder/reservoir connected under the bonnet. A bit more reading needed I think. 2008 G4 RRSport TDV8 current
Fri Jun 02 2017 5:15am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Doesn't need pressure bled. Diag is required to bleed 100% first time, but the system can be run as normal, it will self bleed eventually |
Fri Jun 02 2017 6:26am |
Thanks Mike, when lifting the rear body to get the ARB out do you need to remove the bumper or is there enough clearance ? 2008 G4 RRSport TDV8 current
Fri Jun 02 2017 6:54am |
