Home > Technical > Dynamic
Camelrock
Dynamic
Changing the rear bar soon does anybody know the system capacity was thinking of changing the filter at the same time. Also what's the bleeding procedure many thanks in advance 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #527344 Thu Jun 01 2017 10:56am
2.5 litre capacity. Bleeding done with plug in magic boxes although fairly sure Disco_Mikey will have a simpler method. 2012 SDV6 - it's missing a couple of cylinders
Post #527347 Thu Jun 01 2017 11:35am
Camelrock
Thanks RRRSTDV8 just found a how to showing both diag plug in to cycle the valves but also a pressure bleeder/reservoir connected under the bonnet. A bit more reading needed I think. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #527406 Fri Jun 02 2017 5:15am
Disco_Mikey
Doesn't need pressure bled. Diag is required to bleed 100% first time, but the system can be run as normal, it will self bleed eventually
Post #527408 Fri Jun 02 2017 6:26am
Camelrock
Thanks Mike, when lifting the rear body to get the ARB out do you need to remove the bumper or is there enough clearance ? 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #527410 Fri Jun 02 2017 6:54am
