Home > Technical > Auto to manual= one change down |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Normal your putting the car into sports mode so it drops a gear ready to accelerate or as you e already found out you can select the gear manually. Almost like having 3 gearboxes in 1. Also if I remember correctly in sports mode it won't select 6th gear unless you select it manually with command shift. 2008 G4 RRSport TDV8 current
Wed May 31 2017 2:28pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
That's brilliant thanks very much. |
Wed May 31 2017 2:44pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
No that is a furfy. In Sport Mode it will automatically go into 6th gear but it takes a lot longer to do it - not sure of the exact, parameters but the car has to be going faster than something like 85kph and hold a steady speed for a minute or two - so not likely when driving around town but does it on the freeway - likewise if you are at about 110kph on the freeway and change to sport mode it does not change down to 5th. Going slower - say 80 and it will. garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Thu Jun 01 2017 1:29pm |
It will automatically upshift to 6th in Sport if you venture too far up the rev band too, sort self preservation mode! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jun 01 2017 2:12pm |
