Home > Technical > Auto to manual= one change down
Stevepd
Folks this may be something or just me getting used to the car (2 weeks now). We I move the stick from Auto to +/- it changes down one gear, to which I just + and put it (usually) into 6th. Is this normal?.
2006 RRS HSE 6 speed (sorry don't know which one!).
Steve.
Post #527241 Wed May 31 2017 2:01pm
Camelrock
Normal your putting the car into sports mode so it drops a gear ready to accelerate or as you e already found out you can select the gear manually. Almost like having 3 gearboxes in 1. Also if I remember correctly in sports mode it won't select 6th gear unless you select it manually with command shift. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #527244 Wed May 31 2017 2:28pm
Stevepd
That's brilliant thanks very much. Thumbs Up
Post #527245 Wed May 31 2017 2:44pm
garrycol
Australia
No that is a furfy.
In Sport Mode it will automatically go into 6th gear but it takes a lot longer to do it - not sure of the exact, parameters but the car has to be going faster than something like 85kph and hold a steady speed for a minute or two - so not likely when driving around town but does it on the freeway - likewise if you are at about 110kph on the freeway and change to sport mode it does not change down to 5th. Going slower - say 80 and it will.
garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #527352 Thu Jun 01 2017 1:29pm
Tim in Scotland
It will automatically upshift to 6th in Sport if you venture too far up the rev band too, sort self preservation mode! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #527354 Thu Jun 01 2017 2:12pm
